Is this GP Electronic flywheel wrong?
Posted: Fri Apr 29, 2011 10:09 am
I received this Elemec lightened flywheel late yesterday so couldn't get hold of the dealer I bought it from.
I know that the trigger marks on these flywheels are not gospel and that you have to strobe them but when I offer the flywheel up and line the trigger points up with the pick up on the stator, the ^ firing point on the flywheel is at about 50 degrees before TDC_____ no amount of stator fettling is going to resolve this issue.
These photos show the problem. The smaller flywheel is a light AF flywheel which I've been having problems with at over 6000 revs but it does work and the trigger point generally lines up with the ^ on the flywheel, and the firing point:
The screwdrivers are pointing to the trigger points. If you compare the position of the keyways, they are in the same position. So far so good.
This photo is the other side. Again the screwdrivers are the trigger points. The pencils, however, point to the ^ firing point on the flywheel. As you can see these are miles out if you compare the two.
Before I send this Elemec flywheel back can someone just confirm that i'm not missing something blindingly obvious please
