Page 1 of 2
Coil bound springs
Posted: Sat Mar 14, 2009 10:21 am
by davidblythe
have machined a crownwheel that has 30mm depth and tegether with a foxhat style spider i bought it should be able to fit 5 trad plates or 6 thin plates
the problem i have is the springs are becoming coilbound at approx 16mm which is not allowing me to fit the last cork
any ideas anyone
Re: Coil bound springs
Posted: Sat Mar 14, 2009 10:27 am
by J1MS
Readspeed supplies a set of spring that addresses this issue give him a call....
Posted: Sat Mar 14, 2009 10:36 am
by davidblythe
many thanks
Posted: Sat Mar 14, 2009 10:39 am
by drunkmunkey6969
which springs were you using?
Posted: Sat Mar 14, 2009 10:50 am
by davidblythe
tried every set i have, inc taffy ones, the thin 5 plate clutches all seem to come coil bound 16 to 17mm
Posted: Sat Mar 14, 2009 9:57 pm
by davidblythe
solved the issue by cutting one coil of the springs i had, unfortunately the pressure plate then hit the nut on the xmas tree
shame as still had 3mm of depth unused for the pressure plate to sit in , really needs a modified pressure plate as well to work with 5 standard plates, but can see that it is achievable
Posted: Sun Mar 15, 2009 9:42 am
by muttonjeff
david, what spider are you using.
Posted: Mon Mar 16, 2009 11:09 am
by muttonjeff
david, what spider are you using, af,uprated springs are not for use in a FOXHAT spider,use af,gt springs. also your issue with depth, we have a pressure plate to deal with that.
Posted: Wed Mar 18, 2009 7:36 pm
by muttonjeff
Hi David
Seriously what spider are you using at this momant in time??? Issue- 'Foxhat Style', There is only ONE FOXHAT SPIDER. Please inform us all what a 'foxhat style' spider actually is??
Regards Art and Al- FOXHAT
Posted: Wed Mar 18, 2009 9:41 pm
by sean brady scooters
is it one of those cheap copies............from the other side of the world..................
approx £30.....................?
