HARRY BARLOW NEW BARREL
turbovan
Any 1 havin harrys new barrel kit yet :fb:
not heard much about it tbh but from what i have heard it sounds promising :D
psychedelicropcircle
wots the story ? tourin? race...etc? :o0:
ts1/Rb rival i believe and cast in UK which is nice :D
Knowledge
I have spoken with Harry about these barrels on several occasions since last year's VMSC show, when I took these photos.
And here is the 250 barrel (blank)
As you can see on both barrels, the re-cast item has much more meat at the top and the bottom. This gives a far greater choice with respect to top-n-tailing your barrel to suit longer strokes. Harry has built it to suit a 64mm stroke, even though he hasn't a 64mm stroke in his range (yet).
You will also see that the base of the barrel has loads of meat for opening up the transfer ports at the gasket face. There is also more meat between the fins to allow the trannies to be widened within their length.
The inlet is as per TS1, and the exhaust is the same size to suit the existing range of pipes.
Harry has pistons to suit the 225 and 250 version available from a reliable far east manufacturer.
Martin
turbovan
Going to see harry next week. Got a spanish 150 casing making it into a 200 ,
turbovan
Will have a look at harrys new cranks more money lol
lambrettasam
Any news on when they will be available and the rates? I've sent several emails to Mr Barlow but didn't get a single answer till now.
turbovan
Will get a price next week.He is flat out at min im having a 230cc
lambrettasam
thanks for this mate.
