smoking on tick over and low revs
boxofbits
had the oils seal done about a 3 month ago - bike been fine but still seems to smoke on tick over -alot -but clears up - mid throttle -- no power loss -( when the oil seal went it ran like a dog after 10 mins so iam sure it isnt that) now the exhaust is pretty coked up after the first oil seal went--
what can it be -- the needle worn jet worn -
- checked gearbox oil - just required a cap full to come over the over flow
checked plug and thats wet not black
WINTERMODEL150
Hi,might just be excess oil in the exhaust left over from where the seals went before,try a good run like a 50 miles or so then see if it still is smoking as bad ,re check the gearbox oil after the run to see if its gone down or not this will tell you if the driveside oil seal has gong again.
What oil mix are you using ,check that the choke is coming off fully,what engine and carb set up have you got?
Dean.
boxofbits
ts1 mate runnning a pwk --- going Scarborough so see how it goes sat running ajiit oil 15 quid a pop for chiselspeed
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 2 guests
