Breaking up at just over 6000 revs
Posted: Tue Apr 19, 2011 3:16 pm
I had my TS1 dynoed today at PSL, Kirkby, really just to sort the carb.
The good news was the the jetting was good to go, and the clutch is not slipping anymore. The bad news is that the breaking up at about 6100 revs is an electrical breakdown of some description.
Timing was set at 17 or 18 (can't remember) but was tested with a strobe at about 1/3 throttle.
It's a SIL electronic stator from Scooter Restorations. It's not been run before. All I've done to it is araldite some of the connections. Personally, I've never had any problems with SIL flywheels but I've never run one on a high revving TS1 before.
Stator is one of the later AF lightflywheels with the spacer washers fitted to address the misalignment issue. The pick up does not catch on the flywheel. Again this flywheel has not been used before.
My first inclination inclination was that it's a problem with the stator, possibly the pick up. Anyway, I phoned MB as their website mentions possible issues between AF flywheels and their bgm 120w stators. They believe, and I've seen a post on a scooter forum before about this, that it's the brass rivets on the flywheel that's causing the breaking up.
Any thoughts anyone before I go and buy another part that I don't need
