Pinking & heat seize
Posted: Mon Apr 18, 2011 6:56 am
Hi All
I have already posted this on the LCGB site so apologies to those who may have already read it or posted on it but the more helpful advice the better
Out on the scooter yesterday on 100 mile runabout as I,m coming to the end of bedding in the piston rings to my Stage 4 tuned Iron barrel 225 but noticed sitting just slightly above half throttle (grip has throttle positions marked) at approx 50-55mph it seems that the engine is pinking which then resulted in a heat seize
Now this seemed to happen when the road was flat & the engine not under any great strain by going up an incline.
Timing is strobed at 19 degrees bang on & no air leaks & plug colour at 1/4, 1/2 & at the point of heat seize is a tan colour & squish approx 1.7mm
Setup
28phbh on breath sweet with JL3
50 pilot
AV266 x7 on clip 2
128 Main
I had similar heat seize issues the other week with my 225 Rapido top end which is a spare that I have sitting on the shelf & ran on the same carb settings above
The head is fine as this is the same head I was using on a old 225 rapido setup going back two years ago with no problems & a similar carb set up as listed above with no issues & would sit at 65 all day long.
Help & advice much appreciated as the novelty of going out & then coming home to strip the scooter down each time is wearing thin now
Mike
Setup
50 pilot
AV266 x7 on clip 2
128 Main
Mike
