Ignition Timing for Polini Kit
Posted: Fri Apr 15, 2011 11:17 am
Anyone know what the ignition timing should be for a Polini 207cc Kit (twin ring)
Set up is as follows in case it makes a difference:
Std carb
Taffy Exhaust
Polini Kit.
And also cos i''m a bit thick how do you set up the timing?
I have a timing disc and a TDC gauge but not timing gun.
any advice greatly appreciated.
Russ ;o)
Std carb
Taffy Exhaust
Polini Kit.
Russ ;o)
