rear hub woe
Posted: Thu Mar 12, 2009 11:04 pm
by Tosh
just put my rear hub and cone of my gp150 onto sil 200 stage 4 tried to torque it up to the grin factor and now it is catching on the lip from the back plate where the shoes fit,i`ve noticed that behind were the shoes fit in the hub it is rubing on some bits of bad casting i`m wondering if i should run the dremell down the side to get rid of the prob,has anybody come across this before
Re: rear hub woe
Posted: Thu Mar 12, 2009 11:29 pm
by TS1-200
Have you put the washer/shim behind the cone
Re: rear hub woe
Posted: Fri Mar 13, 2009 11:28 am
by Tosh
TS1-200 wrote:Have you put the washer/shim behind the cone
THANKS TS1 had a bad day at work then did the hub,then at about 11pm last night i had a dream went back down to garage and guess wot I forgot the shim ;) but i slept better, will torque up tonight
Re: rear hub woe
Posted: Fri Mar 13, 2009 8:52 pm
by Tosh
well i torqued it up and it still has a slight wobble on the hub, the hub and cone is off my gp150 so why will it not torque up proper,might i fit 2 shims behind the cone or as anybody got any other idea`s, supposed to go to blackpool tomorrow :(
Re: rear hub woe
Posted: Sat Mar 14, 2009 12:45 pm
by shocky
just check the cone hasnt bottomed out in the hub mine did this i used anither cone and it was fixed, some of the cones i had i measured some were 2mm longer than others , dont know why its just started to do that if its been used before though
