Sh2/22 problem.
Posted: Wed Apr 13, 2011 9:30 pm
by Ihateyoubutler
I have to have the mixture screw set about three and a half turns out to get a decent tickover.It's too weak screwed in any more. Idle jet is a 50 (tried a couple) and can't find any blockages in the carb.Manifold gasket appears ok and the carb is tight on the manifold. Engine is a 200 indian barrel with ports only tidied up and a taffspeed exhaust.
Any ideas what to try?
(Apologise if in the wrong section).
Thanks.
Re: Sh2/22 problem.
Posted: Wed Apr 13, 2011 10:01 pm
by RBG
Is the carb off a 200 motor originally or a 150 motor?
The slide's are different in the 200 compared to the 150.
That could be your problem.
Re: Sh2/22 problem.
Posted: Wed Apr 13, 2011 10:47 pm
by fairspares
or if its a jetex carb change the pilot jet for a genuine dellorto
Re: Sh2/22 problem.
Posted: Wed Apr 13, 2011 11:22 pm
by Diablo
If its a jetex its an airscrew and screwing out will weaken so prob not that
Re: Sh2/22 problem.
Posted: Thu Apr 14, 2011 9:48 am
by Ihateyoubutler
The carb's off a 200 and it's a dellorto.Internals seem correct.Slide has a bit of wear. Are pilot jets bigger than 50 available?
Thanks.
Re: Sh2/22 problem.
Posted: Fri Apr 15, 2011 10:37 pm
by byron
Ihateyoubutler wrote: Are pilot jets bigger than 50 available?
yes http://www.dellorto.co.uk/merchandise/p ... tionID=103
Re: Sh2/22 problem.
Posted: Sat Apr 16, 2011 12:04 pm
by Ihateyoubutler
Thanks for the help.
Re: Sh2/22 problem.
Posted: Mon Apr 18, 2011 6:58 am
by ming
Be sure your air mix screw is of the longer variety which is correct for the 22mm carbs.
