LI s3, revs rising, suspected air leak?
Posted: Wed Apr 13, 2011 10:55 am
by lammysilver
Helping my friend with his S3 LI on the weekend (125, 22mm carb, standard exhaust...), all seems very standard.
It starts after few kicks, doesnt idle at all, after a while the revs rise fast when in neutral at lights etc. making it unridable.
We are just after a few pointers of whats worth checking over before we start and suggestions as to what the cause may be.
cheers
Re: LI s3, revs rising, suspected air leak?
Posted: Wed Apr 13, 2011 7:56 pm
by corrado
Sticking throttle cable maybe. Replacing the cable will be a cheap DIY to rule that out.
Posted: Wed Apr 13, 2011 8:22 pm
by wack 63
Clean carb and fuel tap
Head gasket
exhaust gasket
Inlet gasket
Mag gasket
Oil seals
Base gasket
Just a few to be going on with
Posted: Thu Apr 14, 2011 10:09 am
by paul213
also consider lack of fuel , blocked breather , fuel tap blocked etc
