some ts1 quenstions
Posted: Thu Mar 12, 2009 7:44 pm
hi, I've bought a ts1 225 kit...
I need some specifics to perfect fit
the kit is standard like from af rayspeed, I've just bought an MB manifold for 30mm dellorto carb(that fits inside reedblock)
how is the right piston head clearance? 1mm, 1.2mm,1.5mm
how degrees is timing on ts1 kit
reed block fitting is:
-gasket
-reed block
-gasket
Thanks a lot
P.S. I shall certainly need more of you...
-gasket
-reed block
-gasket
Thanks a lot
