sip carb extensions
roadrunnerian
hi has any one fitted the sip carb bowl extensions i fitted them to my t5 found it flooded when tap left on hard to start and other problems should i fitted a special longer float needle.can anyone help i've took them off now scoot is fine now. thanks
- H,POOL GADGE
- Main scooter: vespa polini220/gts 300
fookin hoy them gadge! shite, they can be sealed, but the sealant also ends up in ye bowl, one tackle fanny gadget that is shite.....
getta cosa float bowl cap and the bigger needle, works a treat!
steeleyscoot
Does anyone know if you can still buy (new) the Cosa float bowl cap and bigger needle?
- H,POOL GADGE
yep! sip do'em gadge!!!
steeleyscoot
Cheers mate, nice one.
