28mm Dellorto PHBH with PM pipe
Mike - - Bristol
Main scooter: Silver Special 195
Hi,
just fitted a new piston and re-fitted the PM exhaust so I need some advice with the carb set up.
I had a quick look through the propper thread but couldn't see this particular set up so, anyone running the following that could give me a head start.
Mugello 186 usual matched ports and transfers,
28 PHBH with ram air filter.
PM exhaust
thanks,
Mike.
Bilko
Main scooter: LI150
I had this on my set up, but without a RAM Air filter
AV264
X7 - 2nd clip from top
50 pilot
40 slide
118 main jet
EDIT: Just to add. Mine was on a Muggy 186
Bilko's Oily Blog
soosh
Again no filter but AV264 with X13 on 2nd clip with115 main.
That was on a 200 with pm.
Mike - - Bristol
thanks guys gives me a start point , and I don't think I'm too far off.
