you know when summats not reet......
Posted: Fri Apr 08, 2011 7:07 pm
by goldeneye
well the malossi has been on the road a couple of weeks, 30mm carb, jl (sip) RH pipe, augusto 6000, light flywheel, 5 plate welded Cosa clutch, ported cases blah blah . gans like f@@k, no pinking (thanks to the augusto) shows 80mph on the old style P200E speedo, and sits at 65mph up hill and down dale, and 60mph into the really strong winds we"ve had up here this week, starts first kick, and does 75miles to the standard tank. but, i dont think its what i"m after. ive had a few malossis before (and probly why i dont want this motor) and they got on my tits by being revvy as f@@k. ive got a very good polini (new style )top end , an MDP barrel with a MAHOOSIVE exhaust port and a malossi piston to fit it, and various P200 barrels, from a Rally barrel, a top and tailed p2 disc barrel, and a spanish DS 200 barrel, that has bigger exhaust and transfers, as standard. so i"m thinking of doing a standard barrel, carb (ive got a 24 and a 26 in the box SI ), and the JL right hand pipe. the DS barrel is favorite at the moment. or should i go Polini?
Re: you know when summats not reet......
Posted: Fri Apr 08, 2011 9:49 pm
by Juan
Talk to Rab (Polossi 220) over on SBW, his bike goes well even given he's about as aerodynamic as an 8' x 4' shed.
Truth told it's a lot of work now that Polini are using a decent piston again these days. Fair enough if you like playing for playings sake.
Posted: Fri Apr 08, 2011 10:05 pm
by buttontobutton
I know exactly what you mean about the Malossi. The last one I had was set up well and was fast, but as you say, after a while they just get on your tits! I ended up selling the 210 kit and going Polini. This was much more of a pleasure to ride. I even ditched my Taffy pipe and used a genuine Piaggio exhaust. Nice and grunty.
The engine I'm putting together now will be based around a ported BGM top end, similar to the set up you are thinking of. But if I had another complete new style Polini kit to hand, I would probably use it over the BGM if I had the choice.
Posted: Fri Apr 08, 2011 11:28 pm
by gadgetman
What exactly are you after?????????
Posted: Sat Apr 09, 2011 7:15 am
by Polossi220
Juan you trying to hurt my feelings Im just big boned
I am running
Polini 210 bored out to take Worb 5 Malossi piston
Exhaust port raised 2mm
Mazza 60mm crank crank webs veed and cut slightly
1.5mm base packer
MRB reed block
28mm pwk carb
and JL right hander
pulls like a train even with my big boned body on it
hard acceleration in first and second gear the front end gets interesting just hovers above the ground.
a couple of my club members have malossi motors and cant keep up
Posted: Sat Apr 09, 2011 8:31 pm
by goldeneye
gadgetman wrote:What exactly are you after?????????
i ended up with the majority of this scooter, and brand new malossi, pipe ,carb, etc, for buttons, all brand new, the guy lost interest, and for 450quid, it was hard to pass up, so its a motor that ive inherited, rather than a spec i would have done for myself. malossis, yeah, they go like f@@k, but i do long haul rallies quite often, and the screaming shite at 65-70mph just gets on me wick. i might pop the polini 207 0n tomorrow. remember, this is also my work scooter, "why have you got a tuned scooter for work?"
and ive got a funny rear end snaking above 60mph, either a nacked shock , or f@@ked wheel (all brand new bits, so an examination tomorrow) won on the national anyway..........................
