smaller carb for ts1???
Posted: Sun Apr 03, 2011 9:26 pm
by mickdale
got a 30mm PHBH carb and lth manifold on my ts1
sick to death of getting loads of s***e all over my bodywork
is there a smaller body carb that i can use with a filter/bellows style set up so it doesnt spit fuel/oil everywhere?
cheers
mick
Re: smaller carb for ts1???
Posted: Sun Apr 03, 2011 9:40 pm
by Muttley McLadd
Is there something else wrong with it? I run an open 30mil on mine. Admittedly, it's not dry on the inside of the panel. But it's not exactly dripping fuel everywhere.
Posted: Mon Apr 04, 2011 7:54 am
by mickdale
Muttley McLadd wrote:Is there something else wrong with it? I run an open 30mil on mine. Admittedly, it's not dry on the inside of the panel. But it's not exactly dripping fuel everywhere.
what main jet you running?
cheers
mick
Posted: Mon Apr 04, 2011 12:43 pm
by corrado
Jimmers / LTH manifold with Mikuni TMX30 should give you enough clearance to use a breath Sweet filter.
Posted: Mon Apr 04, 2011 12:46 pm
by mickdale
corrado wrote:Jimmers / LTH manifold with Mikuni TMX30 should give you enough clearance to use a breath Sweet filter.
thanks for the info martin
thought so - will be back to jetting again :cry:
Posted: Mon Apr 04, 2011 6:05 pm
by corrado
Just remembered that the TMX 32 & 35s are 6mm thinner than the TMX 30. Hence more clearance.
Posted: Tue Apr 05, 2011 9:55 am
by Diablo
Mick its throwing fuel out because its overjetted. I've jetted quite a few TS1s with 30mm PHBH and none run anywhere near what your running.
Posted: Tue Apr 05, 2011 9:02 pm
by gaz_powell
would agree with jetting Ive got two ts1 engines with 34mm dellortos and yes there is some ptrol on panels but nothing like dripping
best of luck
Posted: Wed Apr 06, 2011 3:52 pm
by Train Driver
I have mentioned them before
http://www.lectronfuelsystems.com/
anyone using one yet
