Page 1 of 2
PSI Tyre
Posted: Wed Mar 11, 2009 10:51 pm
by Den 08
hi all just fitted scwalbe weatherman to my gp what psi should i put in it states 44psi max
but seems a bit high i'm using tubes on standard rims. i'm 14-15 stone :oops: helps to keep scot on ground :lol: :lol: i also noticed that there is'nt alot of room between tyre wall and engine case about 4mm should this be of concern?
Den
Re: PSI Tyre
Posted: Wed Mar 11, 2009 11:11 pm
by J1MS
about 18-20 front and 28-32 rear is the normal. 44 psi... is for the tyre to support maximum tyre load, and not for the use you will use it for......
Re: PSI Tyre
Posted: Wed Mar 11, 2009 11:19 pm
by mark
on my series one i run 44 psi 2 up (25 stone approx) and 60k in the trailer ,just get mates to keep an eye on your tyre shape when riding (well thats what i do ) :?
Re: PSI Tyre
Posted: Wed Mar 11, 2009 11:31 pm
by sean brady scooters
the best setting for tyre pressure FOR YOU will vary as to your use/load.............
and is best found from experience/familiarity with your own machine..........
but typically,.......if you find that your tyres quickly go bald in the middle............its over inflated.................. :D
Re: PSI Tyre
Posted: Wed Mar 11, 2009 11:47 pm
by mark
or if side walls look cracked its under inflated :)
Re: PSI Tyre
Posted: Thu Mar 12, 2009 1:21 pm
by Den 08
thanks all :) :)
Den
Re: PSI Tyre
Posted: Thu Mar 12, 2009 1:29 pm
by noggin1969
Or if it handles like a pissed up hippo .......its flat :lol:
Re: PSI Tyre
Posted: Thu Mar 12, 2009 9:56 pm
by cryogenic
Hi Den what size tyre is it your running on i run the weatherman 190 / 10 on the rear and the paceman on the front both on standard rims wide rims wont fit with this size of tyre on the rear due to engine casing clearence i ran at 35psi to sweden and back. A little wear was noticed but i put this down to over 2300 miles being covered and i was towing a trailer.
kind regards :)
Re: PSI Tyre
Posted: Fri Mar 13, 2009 9:34 pm
by Den 08
32 in rear 28 in front
100-90 on standard rims
done about 30miles today felt good no marks on engine case tyres nice and warm.
going to sandford tomorrow i'll give'em a good run :!: :!:
Den
Re: PSI Tyre
Posted: Fri Mar 13, 2009 9:45 pm
by Dazza
noggin1969 wrote:Or if it handles like a pissed up hippo .......its flat :lol:
Have you ever ridden a pissed up Hippo then Shaun?? :D best not answer eh? :D
