lambretta ts1 rear shock
carlos
noob
Main scooter: lambretta
the frame is touching the inlet manifold, so is the easy fix putting a shorter shock on, the one on now is 300ml ?
hydra
Are you using standard Inlet Manifold? If so get MBD Manifold. or Offset Cones. I have MBD Manifold with 5mm packer for Boyssen Reeds and only Rear damper that fits so far is Taffspeed. But I'm sure without the packer I could get a BGM on.
    Users browsing this forum: Google Adsense [Bot] and 6 guests
