Page 1 of 5
wont start
Posted: Mon Mar 28, 2011 11:02 am
by Piatti
Just rebuilt a series 3 125 and now it wont start, was running previously. Has got got fuel with 3% mix, timing set to 19 degrees, checked piston is in the correct way this morning, am getting a healthy spark when plug is held on engine casing, if I take the air filter off and cover the carb with my hand when I kick over its wet with fuel.
Any suggestions :?:
Regards
Piatti
Re: wont start
Posted: Mon Mar 28, 2011 12:00 pm
by Mickey C
had many similar problems myself - the one that took me the longest to figure out was a blocked exhaust.
if plug is wet and spark looks good - maybe worth checking.
Re: wont start
Posted: Mon Mar 28, 2011 12:41 pm
by corrado
Is the plug wet too when it won't start?
Re: wont start
Posted: Mon Mar 28, 2011 12:52 pm
by Piatti
Mickey C wrote:had many similar problems myself - the one that took me the longest to figure out was a blocked exhaust.
Plug is wet after kicking over several times, I'll check the exhaust tonight and report back
Re: wont start
Posted: Mon Mar 28, 2011 12:55 pm
by tea5ive
could be excess oil in cylinder after rebuild. try warming the plug up (nice and hot) before starting
Re: wont start
Posted: Mon Mar 28, 2011 5:11 pm
by Piatti
Ok, checked exhaust its not blocked, when I kick the scooter I can feel the air expelled from the exhaust.
Heated up plug and tried kicking over but still not starting... :(
Re: wont start
Posted: Mon Mar 28, 2011 5:42 pm
by dapper
Points or electronic? I'd double check the timing is 19 degrees BTDC too.
Re: wont start
Posted: Mon Mar 28, 2011 5:47 pm
by RICSPEED
gap the plug or change it ...i have known plugs to spark ok out of the head but not work under compression
Re: wont start
Posted: Mon Mar 28, 2011 6:16 pm
by Piatti
Brand new plug, which I have swapped with another brand new plug and checked...
electronic ignition, timing done with TDC tool and timing disc by myself...
Re: wont start
Posted: Mon Mar 28, 2011 6:46 pm
by RICSPEED
Piatti wrote:Brand new plug, which I have swapped with another brand new plug and checked...
try closing the gap on the plug then try it
