Del'Orto or imposter?
Posted: Sun Mar 27, 2011 9:51 pm
by mytyresarepumped
Anyone know how I recognise a T5's Dell Orto carb? Just wondering if it carries some way of identification or authentication. Wondering if I can identify it without having to remove it. Cheers.
Re: Del'Orto or imposter?
Posted: Mon Mar 28, 2011 8:21 am
by AUSSIE
If you take off the air filter on top of the carb you can see the size stamp on the carb, you should see 24/24g if its off a T5.
the carb is also a bit shorter than a P2 carb as it is made to go with the improved air filter which is deeper but has to fit inside the standard air box.
