Del'Orto or imposter?
mytyresarepumped
Main scooter: VespaT5Mk1
Anyone know how I recognise a T5's Dell Orto carb? Just wondering if it carries some way of identification or authentication. Wondering if I can identify it without having to remove it. Cheers.
AUSSIE
If you take off the air filter on top of the carb you can see the size stamp on the carb, you should see 24/24g if its off a T5.
the carb is also a bit shorter than a P2 carb as it is made to go with the improved air filter which is deeper but has to fit inside the standard air box.
