badge question
Posted: Fri Mar 25, 2011 8:58 pm
by sydduckett
Can anyone tell me what the correct fixing clip is for INNOCENTI SQUARE TYPE HORNCAST BADGE .FITS LATE TYPE LI3 SX (sorry about caps pasted it... :D
Links appreciated, it has 5 pins on the back with one being in the middle.
Ta
Sef
Re: badge question
Posted: Fri Mar 25, 2011 9:31 pm
by soulsurfer
http://www.scooterrestorations.com/lamb ... adge-clip/
Mind you, they normally have a small nylon insert in the middle in which the middle pin on the badge goes, the other four pins just locate in the horncasting recess.
Re: badge question
Posted: Fri Mar 25, 2011 10:48 pm
by sydduckett
soulsurfer wrote:http://www.scooterrestorations.com/lamb ... adge-clip/
cheers for that, doesnt look as though they sell the nylon insert..... :evil: and im guessing its not going to be anywhere near tight eneough without it.... ;)
Any suggestions on where to locate this bit, im going to do some searching. Not sure what to type though.... :? :D
Re: badge question
Posted: Fri Mar 25, 2011 10:55 pm
by soulsurfer
I'd check with SR, they've always come with the ones I've bought from different places, but most dealers sell the complete clip.
Re: badge question
Posted: Sat Mar 26, 2011 1:02 am
by 22/2
Nylon centre???
You'll have to check the sizes, it equals 4.7 mm X 3.175 mm, which is about right I think.
I have also bought them from Scootopia for the rear frame badge on a GP.
Rich
Re: badge question
Posted: Sat Mar 26, 2011 8:08 am
by soulsurfer
22/2 wrote:Nylon centre???
Rich
40 of 'em, that should last a while...!
The clip should come with it anyway, mine always have, but judging by the SR pic, maybe you need to check... it may just be a mistake in the picture.
If you do check with SR can you let me know?
Re: badge question
Posted: Sat Mar 26, 2011 2:13 pm
by dapper
You may find they are the same size as the ones SR do for the rear frame loop badge (as for SIL badge) I got some with my badge from SR
http://www.scooterrestorations.com/lamb ... ame-badge/
Item No. 5 at the rear
http://www.scooterrestorations.com/lamb ... transfers/
Re: badge question
Posted: Sat Mar 26, 2011 4:07 pm
by sydduckett
Rich
Iv ordered it and asked that they include it. will let you know what they say or when it turns up.
Ta
For the help.... :D
Re: badge question
Posted: Sat Mar 26, 2011 4:12 pm
by sydduckett
dapper wrote:You may find they are the same size as the ones SR do for the rear frame loop badge (as for SIL badge) I got some with my badge from SR
cheers dappa
