complete list of engine parts ?
Before starting on the final build of an engine, I like to get everything cleaned, up, checked and ready to refit, so making the assembly as smooth as possible.
It's helpful to have a list to check things off, which is also handy as an engine is dismantled, to see what needs replacing etc.
But is this a complete list ??
casing
brake arm
brake arm circlip
brake cam & shim
brake cam grease nipple
brake shoe circlips & plates
brake shoe pivot pins & washers
brake shoe spring
brake shoes
bumpstop
bumpstop washer
chain
chain guide nuts & washers
chain guide studs
chain guide, bottom
chain guide, top
clutch arm
clutch arm spring
clutch bellhousing
clutch circlip
clutch corks
clutch lever
clutch nut
clutch shaft
clutch shaft circlips x4
clutch shaft o ring
clutch shim
clutch spider
clutch springs
clutch steels
clutch tab washer
clutch thrust thimble / brass bush
clutch top plate
crankshaft
crownwheel
crownwheel bearings / bush
cylinder
cylinder cowling
cylinder head
cylinder head nut kit
cylinder studs
drive side bearing
drive side bearing plate screws
drive side seal
drive side seal plate
drive side washer
endplate
endplate bearing
endplate bearing circlip
endplate dowels
endplate nuts
endplate shim
endplate studs
endplate washers
engine bolt
engine mounts
engine studs 14 x M6x33
exhaust casing studs 2 x M8
exhaust cylinder studs M7
exhaust gasket
exhaust header pipe
exhaust nuts & washers
flywheel
flywheel cowling
flywheel dustcover
flywheel dustcover circlip
flywheel nut & washer
front sprocket
front sprocket bolt
front sprocket collar
front sprocket oil thrower washer
front sprocket sliding dog
front sprocket spring
gear cog loose 1st
gear cog loose 2nd
gear cog loose 3rd
gear cog loose 4th
gear selector balls
gear selector pin clips x2
gear selector pins x2
gear selector shaft
gear selector shaft bolt & washer
gear selector shaft bush
gear selector shaft o ring
gear selector spring
gear selector wishbone
group cluster
group cluster bearing outer track
group cluster needle bearing
group cluster shim
group cluster track shim
inlet gasket
inlet manifold
inlet nuts & washers
inlet studs
kickstart buffer
kickstart circlip & washer
kickstart inner bush
kickstart lever
kickstart outer bush
kickstart piston
kickstart piston pin
kickstart piston plate
kickstart piston spring
kickstart ramp
kickstart ramp bolts & washers
kickstart seal
kickstart shaft
kickstart spring
kickstart stop
layshaft
layshaft bearing bush
layshaft needle bearing
layshaft o ring
layshaft shim
mag housing
mag housing bearing spacer
mag housing circlip
mag housing gasket
mag housing grommet
mag housing inner seal
mag housing outer seal
mag housing stator wiring plates
mag housing stator wiring plates gasket
mag housing studs 3 x M6x25
mag side bearing
oil drain plug & fibre washer
oil filler cap & fibre washer
oil level plug & fibre washer
piston
piston pin
piston pin circlips
piston rings
rear bearing
rear bearing flange studs 4 x M6x21
rear bearing flange thick
rear bearing flange thin
rear bearing housing nuts & washers
rear bearing seal
rear hub & cone
rear hub nut & washer
rear hub nut lockwasher set
rear hub spacing washer
side casing
side casing dowels
side casing gasket
side casing nuts & washers
small end bearing
stator
stator bolts & washers x3
stator wiring clip
woodruff key
doesn't go as far as carb or pipe or rear wheel, or gear linkages, but otherwise ready to bolt in and run.
Of course, slight variations exist between a GP & Li angine, but any errors or omissions ??
thanks
Knowledge
Thanks for that list Jarv. I was wishing someone would publish such a list. I will check it out during my rebuild and gove you some feedback.
The bad news is that the list looks much, much longer that the pile of bits I have sitting in a box down the workshop. :oops:
Martin
Knowledge wrote: I will check it out during my rebuild and give you some feedback.
cheers martin, appreciate that. it is quite a long list...
sideout
The Scooter Restorations Catalogue is a pretty good guide to what bits are required, for the whole scooter not just the engine.
I've been known to make a spreadsheet based on this to do exactly what you want to do... :oops: :geek: :lol:
kejj
http://www.barkas.se/lambretta/Lambrett ... efault.zip
Spreadsheet with columns for replace and OK mark.
________________________
http://tv175.wordpress.com/
kejj wrote:http://www.barkas.se/lambretta/Lambrett ... efault.zip
willwander
That's a long list, here's one for you, how many individual parts are on a standard GP200? It's got to be a lot.
We could have a sweepstake, like guessing penny's in a jar
standing mile: 118.6mph
dirtyhandslopez
Couple of things that don't appear to be there.
Kickstart piston circlip
Kickstart stop washer.
Laying out al the parts for a rebuild after they've all been cleaned is like building a big 'ol jigsaw puzzle. Love it :)
That's not going anywhere...
kejj
updated
