Page 1 of 3
Water Temp
Posted: Tue Mar 22, 2011 9:32 pm
by Bilko
For running normal round town. How long would it take to get the water temperature up over 40 degrees C?
Re: Water Temp
Posted: Wed Mar 23, 2011 4:23 pm
by mark
mine ticking over takes about 5 mins but about 2 mins if im riding. this all depends on where you temp sensor is situated and if you using a thermostat and water pump. i cant remember what my thermostat opens at sadly ,hot water is then pumped around to rads when it opens(pump runs all the time)going past my sensor and fan switch which are in the pipe from pump to rad. on the motorway in belgium it was reading 57-62 c, around town it was reading between 75-85 c. i am now moving my sensor into the head to get a truer reading of running temp and putting fan switch into rad mainly to tidy things up
Re: Water Temp
Posted: Wed Mar 23, 2011 5:50 pm
by Wayne Miller
Bilko wrote:For running normal round town. How long would it take to get the water temperature up over 40 degrees C?
It depends on wether your using an addittional head gasket and increasing your squish or not :shock: :shock: :shock: :shock: :shock:
:frog:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Hope all goes well for you mate ;)
Re: Water Temp
Posted: Wed Mar 23, 2011 10:53 pm
by Bilko
Thanks Mark
LOL! Thanks Wayne.
Now I know my water temp gauge isn't working.
Re: Water Temp
Posted: Wed Mar 23, 2011 11:04 pm
by Wayne Miller
Bilko wrote:Thanks Mark
LOL! Thanks Wayne.
What are you using? mine doesnt start to register until the temos above 30 c.
Mines Vapourtech Stealth or at least I think thats what its called :lol:
Mine starts to register after about 2/3 mins at tick over
Re: Water Temp
Posted: Wed Mar 23, 2011 11:25 pm
by Bilko
TIm Temperature gauge.
I think it could be the sender. It's a Koso one, but the connector was unique so I took it to an electrical shop where they put connectors on the wires.
I dunno.
I might try and see if I can find another sender, but I don't know what the tapered thread size is on the connector.
AAAaaaaarrrrgggghhhhhhh!
I'm off to bed before I get another headache!
Re: Water Temp
Posted: Thu Mar 24, 2011 3:07 pm
by Bilko
Now sorted to what I need to do. I've ordered a sender/sensor and this should sort it out.
Re: Water Temp
Posted: Mon Mar 28, 2011 11:27 pm
by Bilko
or maybe not! Is there a way to test if the gauge is working?
Re: Water Temp
Posted: Thu Apr 21, 2011 8:38 pm
by Bilko
It looks like the water temperature gauge is f@@ked.
A mate came round tonight and pointed out I'd connected it up wrong. :oops: :oops:
Re: Water Temp
Posted: Thu Apr 21, 2011 8:48 pm
by mark
