squish on T5 malossi 172kit
Posted: Tue Mar 22, 2011 2:08 pm
by Tosh
when i striped the scoot down to change the main oil seal i noticed that there was no head gasket and i didn`t check the squish, i`ve now got all my new parts to start the re build but was wondering if i should put the new head gasket on or leave it off if the squish is correct,and do i check it like when i`m sorting the lammy out,through the plug hole or as i do put plasticine on top of the piston,
Re: squish on T5 malossi 172kit
Posted: Tue Mar 22, 2011 9:25 pm
by H,POOL GADGE
no worries gadge! repair and rebuild your engine, put head on as it was without gasket and check the squish, with a cross of plasticine across piston crown or soldier through plug hole, then you,ll know if it needs the gasket or not....
Posted: Tue Mar 22, 2011 10:45 pm
by Tosh
thanks H,POOL GADGE for that, what size of squish am i looking at please.
Paul
Posted: Tue Mar 22, 2011 10:49 pm
by H,POOL GADGE
1.2mm
Posted: Tue Mar 22, 2011 11:16 pm
by Tosh
thanks again, an safe riding
