Using BMEP to calculate TA ?
Wayne Miller
Does anyone know how to calculate TA from BMEP figures ?
Or know of any sites that could help me discover the formula?
Cheers Wayne
Stay tuned..............
Wayne Miller
eden wrote:i'm not sure about this or what assumptions are made but try these: I didn't add these to the lambretta-images timing calculators because as i say, I'm unsure where the formula came from or if its correct.
BMEP(bar) + 9.66 / 2400 = TA (transfers for higher primary comp)
BMEP(bar) - 0.128 / 587 = TA (transfers for lower primary comp)
Cheers for that mate. I already have those figures, there quotes from Blair. I was just writing a reply to you say that RPM was missing from the equasion and that you obvioulsy need it as TA changes with RPM. Then I had a Eureka moment and realised that RPM was already there in the BMEP figure!!! :D :D :D :D :D
The only problem is, Im not calculating my BMEP in bar. I need to find the calc for this now. :roll: :roll: :roll: :roll:
Wayne Miller
PSI/14.503795 works it out roughly
cheers mate
Wayne Miller
Heres all of the rest mate, BMEP are all in bar
INLET
((BMEP+1.528)/774)
TRANS UPPERBAND
((BMEP+9.66)/2400)
TRANS LOWERBAND
((BMEP-0.128)/587)
EXHAUST
((BMEP+5.975)/1050)
BLOW DOWN
((BMEP-1.75)/8187)
;) all of the figures can be confirmed in blairs book page 432. He writes them in a more complicated/intelligent manner but thats how to do it above in laymans terms ;)
Thanks for your replies mate, helped get me thinking on the right lines again.
Im off to find the answers to the next puzzle ;)
