H4 headlight conversion
Posted: Sun Mar 20, 2011 10:34 am
by 10 inch Terror
Hi all, can anyone tell me if these conversions are worth doing now that you can buy Xenon type bulbs for standard Lammy headlight holders. Only i knocked up an H4 conversion a few years back and wondered if it was worth fitting. I'll post some pictures and would be grateful if anyone could tell me if what i have will work or if i need to do anything else to it. Cheers Pete
Re: H4 headlight conversion
Posted: Sun Mar 20, 2011 11:57 am
by Speed Demon
IMHO this solution is lots better than any of the conversion bulbs I've tried.
Posted: Sun Mar 20, 2011 12:02 pm
by wack 63
They work fine you just have to get the focal point set right to get a good beam.I think the bulbs casing needs to protrude around 5mm forward of the original holder.I usually take the headlight off,wire up to a battery,fit the holder then play about with focal settings till it gives a good beam on a wall before finally fitting to scoot.
Posted: Sun Mar 20, 2011 12:05 pm
by 10 inch Terror
Si can basically fit it as it is or do i need anything else? Thanks for your comments sp far. Pete
Posted: Sun Mar 20, 2011 12:18 pm
by soulsurfer
Speed Demon wrote:IMHO this solution is lots better than any of the conversion bulbs I've tried.
Sticky, did you ever try this on Varitronic?
