t5 172 stutter on pulling away
Posted: Sat Mar 19, 2011 8:07 pm
by cezeta
t5 172 malossi standard carb and sito plus
as i pull away once the motor has been running for 15 mins there is a stutter as if ive hit the kill switch then it picks up with a jolt. it feels as if its between jets.
now and then it will give a backfire noise but not a bang but more of a release of pressure noise like a woopey cushion in the exhaust or air brakes.
when the engine is cool its ok though. is this an air screw issue?
any thoughts apretiated. (yes ive checked there isnt a woopey cushion in the pipe)
Re: t5 172 stutter on pulling away
Posted: Sat Mar 19, 2011 10:20 pm
by C*NTSPEED
As this is doing it once its a bit warm i would be thinking pick up..my old 172 had the same symptom but im sure thete are better people with better ideas on it maye
Posted: Sat Mar 19, 2011 10:53 pm
by cezeta
i let it cool down and two hours later went for a spin and its crisp as anything again. ive been riding bikes so i cant judge if it feels fast or slow as my judgment goes a bit sque-wiff but its definately sluggish and hesitating when hot.
ive got a nos stator so that can be changed. is the puller the same as a p2 ?
any more thoughts would be apretiated
Posted: Sun Mar 20, 2011 12:07 am
by C*NTSPEED
yes puler is same pal...mine was ok when cold it was just when warm but it could be anything electrical ie,plug,cap,ht lead,cdi
Posted: Sun Mar 20, 2011 7:58 pm
by cezeta
new coil, new stator, cleaned carb, adjusted air screw but it still farts if i de exelerate with the throttle closed then open it to 1/4 again.
it poppes out of the exhaust still.
help
Posted: Sun Mar 20, 2011 8:09 pm
by sean brady scooters
have you had it dynoed ,does it really have a T5 carb on and not perhaps a P200 one ...as the slide itself is different and makes a difference ...?
Posted: Sun Mar 20, 2011 9:05 pm
by cezeta
no not dynoed, train driver is going up to diablos soon so i may tag along.
how do i tell the differance between the p2 and t5 carb?
