Page 1 of 2
Enhancing mugello
Posted: Fri Mar 18, 2011 1:06 pm
by suedehead
Got a 225 mugello,28mm delorto,lth reedvalve,franspeed race exhaust,lightened af flywheel and stator and august box,goes great all the way from bottom through to 75mph,but cant help thinking what else can i tinker with :baddevil: without blowing it up of course-any ideas?
Re: Enhancing mugello
Posted: Fri Mar 18, 2011 1:40 pm
by paulmgreen
is the barrel actually ported?
Posted: Fri Mar 18, 2011 2:25 pm
by Knowledge
Have you cut holes in the skirt of the piston since you fitted the reed?
You could get probably get more top-end if you took the LTH reed off, but that might not be what you want. Actually, what more do you want?
Posted: Fri Mar 18, 2011 2:53 pm
by coaster
I have to agree with Knowledge, if that is a GPS measured 75mph then I'd leave well alone. If not already done, holes I'n piston skirt, additional transfer cut from inlet to level with top o transfers, open inlet port up as big as possible without allowing ring ends to project into port, raise and widen the exhaust. With the exception of the exhaust port, I have done all that to my 225 Indian kit but it tops out at 67 GPS
Posted: Fri Mar 18, 2011 3:15 pm
by Bilko
suedehead wrote:Got a 225 mugello,28mm delorto,lth reedvalve,franspeed race exhaust,lightened af flywheel and stator and august box,goes great all the way from bottom through to 75mph,but cant help thinking what else can i tinker with :baddevil: without blowing it up of course-any ideas?
I don't know if my Reaper tuned 225 Muggy would have done any better than that.
I'd be happy enough with that on mine.
Posted: Fri Mar 18, 2011 6:51 pm
by rbgaz
what ever u do dont buy a vapour speedo or sat nav it u b even more pissed off lol
Posted: Fri Mar 18, 2011 10:12 pm
by suedehead
Thanks for the advice, no porting work or holes cut in piston,runs reliable,starts easily-revs like a bike quiqkly through gears-did 75 on dyno with 18bhp-i have a vapor speedometer on it-wouldnt mind a little more top end but not at the expense of losing the bottom grunt-someone did say to me leave it as its fine as it is,tinker with it and you,ll make it unreliable-just wondered what the options were for different types of increased performance
Posted: Fri Mar 18, 2011 10:17 pm
by sean brady scooters
eerm ,75 on the dyno does not mean 75 mph on the road does it ?
Posted: Fri Mar 18, 2011 10:41 pm
by suedehead
no it dosnt but before dyno it went fast enough to top lambretta speedometer which i know is no great guide,ill have to see what the vapor says when im feeling daring
Posted: Fri Mar 18, 2011 11:42 pm
by cezeta
i have a similar spec engine, 12.5bhp with a clubman and 16 with a kegra race pipe.
the mugello is not pitched at being much more than this and in my mind i would stop spending on a slow kit to make it faster and just buy a faster kit.
there are a few that are binning ts1s for a more "standard ride" so a barrel swap would be what i would be looking at.
