PX 200 clutch problem
vespanoob
noob
Hello guys, I'm experiencing "clutch creep" on my PX2 when engaging first gear, and engine wants to die because of this. I've tried adjusting it using the adjuster screw on below, but still no luck. Kick start lever is useless if I adjust too much, if I back it out again, still "clutch creep". What could be wrong here? The clutch is an 8 spring, banded (SeriePro) from SIP, new springs (L), new plates, and all other clutch components seem to be in order. What am I missing here?
you need to mill the turrets down to approx 22mm.
goldeneye
if its a serie pro clutch , dont go milling anything off it. instead, get a slimmer oil drive cog/ clutch spacer, (SIP do them in 1mm thinner size) you may have to ditch any autolube you have. you can machine the original drive cog , but they are hardened steel.
    Users browsing this forum: Semrush [Bot] and 25 guests
