rapido 250 with vhsa 32 delly anyone?
Posted: Thu Mar 10, 2011 9:19 pm
by king of the hill
got a rapido 250 with ADS3 exhaust and a VHSA32mm dellorto .
got this carb from another project so might use it for the rapido , anyone got any suggestion what jettings , slide ect to start with ?
cheers
tim
Re: rapido 250 with vhsa 32 delly anyone?
Posted: Sun Jul 22, 2012 1:32 pm
by king of the hill
finally finishing the rapido still could use some ideas for the jetting ;)
vhsa 32
55slide
U7 needle
DQ262atomiser
145 main
40 starter
60pilot
with clip on second position way to rich first half of throttle , better with clip on highest position but still too rich first quarter of throttle , any suggestions ?
Posted: Sun Jul 22, 2012 1:58 pm
by Darrell Taylor
try a smaller pilot jet and spend time on the mixture screw to get it running clean off the bottom
? what ignition and timing you running?
Posted: Sun Jul 22, 2012 3:18 pm
by king of the hill
scooterrestorations ignition set at 19BTDC
think i mixed up the pilot and starter jet in previous post , should be 60 starter and 40 pilot
did some work on the mixture screw still too rich on thick over and on first part of the throttle
could it be the needle ? not familiar with these carbs .
Posted: Sun Jul 22, 2012 5:30 pm
by Darrell Taylor
no probs with lack of advance then at 19 degrees
im not too familiar with the carb either
have u tried back to back on mix screw at 1/4 out against 3.5 out with tickover reset accordingly whats it like best as that gives an indicator of what to do with pilot size,i think its an air mix screw so if it likes 3.5 try a smaller pilot
is the rapido std or tuned as long inlet timing will be difficult to set up
