PX 200 clutch problem
Posted: Thu Mar 10, 2011 2:31 pm
by vespanoob
Hello guys, I'm experiencing "clutch creep" on my PX2 when engaging first gear, and engine wants to die because of this. I've tried adjusting it using the adjuster screw on below, but still no luck. Kick start lever is useless if I adjust too much, if I back it out again, still "clutch creep". What could be wrong here? The clutch is an 8 spring, banded (SeriePro) from SIP, new springs (L), new plates, and all other clutch components seem to be in order. What am I missing here?
Re: PX 200 clutch problem
Posted: Thu Mar 10, 2011 2:41 pm
by sean brady scooters
you need to mill the turrets down to approx 22mm.
Posted: Thu Mar 10, 2011 8:10 pm
by goldeneye
if its a serie pro clutch , dont go milling anything off it. instead, get a slimmer oil drive cog/ clutch spacer, (SIP do them in 1mm thinner size) you may have to ditch any autolube you have. you can machine the original drive cog , but they are hardened steel.
