TS1 and 28mm carb
CPH Lambretta
Main scooter: DL 150 1970
Is a PHBH 28mm carb big enough to go on a TS1? The porting on the TS is pretty standard and will be touring not racing. So can I use the 28mm I have or do I really need to go up to a 30mm?
Anyone running a TS1 with a 28mm carb?
Cheers Nick
Slow is the new fast!
Speed Demon
It will work fine. When we used to do scootercross Taffspeed put a 28mm carb on a TS1 for Bob West to race off road and on the dyno it lost no power compared to the 34mm Amal they had on before, but gained low end response.
Get to SULK
CPH Lambretta
Sounds good, just what I wanted to hear :)
