Page 1 of 2
malossi 166 gearing
Posted: Wed Mar 02, 2011 2:27 pm
by vesparox
cheers guys...
wht is the best gearing for malossi 166??i'm more into top end...cause most of my ride is on a highway....
hope you guys can help me...
Re: malossi 166 gearing
Posted: Wed Mar 02, 2011 3:34 pm
by buttontobutton
A clutch drive cog upgear, 21 or 22 teeth will be useful, depending on your pipe and the rest of your set up. 22 is taller obviously and would get you a higher top speed, but might be too tall depending on your exhaust and the rest of your set up.
I once had a 166 with P200 primaries but this was only any good when going down hill with the wind behind you. Then it was great!
Posted: Wed Mar 02, 2011 11:05 pm
by Diablo
If the casings are matched properly and the inlet timing done right then it should pull 22/68 easily.
I have seen a few with 23/65 and have one in the workshop at the mo. It does feel overgeared to me but the guy that owns it is about 4ft tall and 7 stone so will no doubt be fine for him.
Posted: Thu Mar 03, 2011 5:13 pm
by OzOAP
As Al said, transfers and timing need to be sorted.
Mine pulled 23/65 with P125 gears ok, but I also fitted a 60mm P2 crank. Made it a 175cc. Well worth doing. 30mm PHBH and PM pipe.
Used it as my rally going engine for a few years.
Engine is now in my 'crosser' with 20/68
Posted: Thu Mar 03, 2011 8:17 pm
by vesparox
thanks guys for the replies.....
my set up is...malossi 166 with casing matched...spaco26-26 carb,,simmoni exhaust...std px crank....
would this set up have the power to pull the 23/65 gearing???
Posted: Fri Mar 04, 2011 2:04 am
by Diablo
yes
Posted: Sat Mar 05, 2011 1:19 am
by MattsDad
No
Posted: Sat Mar 05, 2011 1:27 am
by james lancaster
lml gear box are worth a try there 4th gear is better then the t5 it pulls alot quicker in 4th as ive tryed it against a piaggio 125 box with t5 4th gear beat the other scoot in every gear
Posted: Fri Mar 11, 2011 7:29 pm
by vesparox
ok,,last week i try to put the 23/65.....it pull very quick...but in 4th gear its start to scream very bad..and vibrate also...any ideas whats going wrong...then later,i put the 22/67 back....there no vibrate at all....please help me guys....
Posted: Sat Mar 12, 2011 11:17 pm
by james lancaster
i use a malossi 166 i have lml gear box and its spot on i use my everyday and can not fault it one bit
