Vespa PX speedo drive retaining bolt
Hedges
Xbox live gamer tag: Northerncoaster
Main scooter: PX200
The small bolt at the forks has snapped and refused to come out. I tried drill so I could tap it again but it started to go offline.
Question is can I wedge in the metal barrel and rubber bung so to keep the drive in place. Is there much force when spinning and will this just pop them out? Cheers
Norrie Bodge
If you’ve already drilled & it’s past the stage that you can’t get an easy out on it?
Use a stainless self tapper screw to hold the retaining plate in position
GL
