22mm jetex against 25mm dell
Posted: Sun Mar 08, 2009 3:03 pm
by Andy Pickering
I am thinking of dropping to standard 22mm jetex on my brand new sil 200 engine with Rscoot exhaust just to get it run in then have another go with my 25mm dell just a bit worried of holeing piston, now would it need jetting any for the exhaust at all and it would have casa hose upright with K&N on...If i change down would be looking for one already have manifold.
Andy.
Re: 22mm jetex against 25mm dell
Posted: Sun Mar 08, 2009 6:34 pm
by rog60
I would tend to stick with the Delorto as I have a similar 200 SIL engine +Indian clubman fitted with a Jetex(118 Main jet). Although I am in no way an expert you would almost certainly have to go up a few sizes main jet to get over the Rscoot Pipe and free flowing K&N filter effects.
Jetex are can be difficult to set up as the main jet is the only real way to alter mixture throughout the rev range and I personally don't rate them but if on a budget they are good enough.
Perhaps someone has more detailed/accurate views?
Posted: Sun Mar 08, 2009 6:37 pm
by bristolmod
why not whack on a Jetex and a standard exhaust just to run in???
Posted: Sun Mar 08, 2009 6:43 pm
by Andy Pickering
bristolmod wrote:why not whack on a Jetex and a standard exhaust just to run in???
To be honest chris i like the noise (sad ill get me coat)
Posted: Sun Mar 08, 2009 6:46 pm
by bristolmod
Of course- there is that to it!!
(I'll get mine as well..............)
C
Posted: Sun Mar 08, 2009 8:17 pm
by rog60
Posted: Sun Mar 08, 2009 8:29 pm
by Andy Pickering
Posted: Mon Mar 09, 2009 12:21 am
by rog60
Posted: Mon Mar 09, 2009 12:30 am
by sean brady scooters
std 200 indian motor...........using 22mm carb..........scootrs pipe.........123 main jet.......................but only running through std air box.....................
Posted: Mon Mar 09, 2009 10:50 am
by Andy Pickering
sean brady scooters wrote:std 200 indian motor...........using 22mm carb..........scootrs pipe.........123 main jet.......................but only running through std air box.....................
Got 30mm Dellorto on the way..
