Riddle me This
Posted: Fri Feb 25, 2011 10:32 am
Before I spend the day frustrated & wasted, I've a problem I don't get.
Bear with me, it's early and my brain hasn't fully downloaded yet.
Gear cables.
In the headset they are as they should be. The outers are sat in their slots in the headset clamp.
At the other end the outers are sat in the adjuster block properly.
So, I tighten the cables up, but once I try to put into gear they become loose at the adjuster block.
What the f@@k is going on here? It keeps happening.
Gear cables.
