Kickstart Shaft Piston
Posted: Wed Feb 23, 2011 3:02 pm
by Bilko
I've got nothing to compare, so could someone tell me if this piston is sticking out too far? To me it looks like it's sticking out too much, but the kickstart shaft is new as far as I can tell.
Re: Kickstart Shaft Piston
Posted: Wed Feb 23, 2011 3:28 pm
by dapper
Rob, I think you'll find that it's the ramp that controls how far out the piston sticks. You do have the Kick Start Piston Circlip on, don't you?
Posted: Wed Feb 23, 2011 3:38 pm
by Bilko
Circlip is in. I've no ramp on my casing
Posted: Wed Feb 23, 2011 3:57 pm
by dapper
But if you have a GP ramp built into the GP endplate, you'll have to turn the kickstart shaft a bit to line up the reference pin with the ramp?? That should hold the piston in a bit
Posted: Wed Feb 23, 2011 4:06 pm
by Bilko
Suppose it's the only option left. Cheers.
Where did I see the article on prep and fixing on?
Who does the ramps?
Posted: Wed Feb 23, 2011 4:17 pm
by Bilko
Doesn't matter. I'll have to get another kickstart shaft
Posted: Wed Feb 23, 2011 7:20 pm
by DaveTomo
I don't know if this helps,I did one on the LCGB site about 8-9 months ago and I think it was also done recently in classic scootering.This is the way I did mine so that I kept the GP endplate which was matched to the engine casing.Take the endplate off and using a dremmel trim the ramp off so that it looks like an LI,SX etc endplate before
after
compare
drill and tap the blanks on the sidecasing assuming its a GP sidecasing and fit a ramp,I think you can them most places got mine from SR ,(think they're out of stock at the moment)
http://www.scooterrestorations.com/lamb ... and-bolts/
ramp fitted
endplate fitted
All works,takes the strain of the kickstart off the endplate and you can adjust the kickstart "biting" point better plus you've got the stronger GP kickstart shaft.Hope this helps.Dave
Posted: Wed Feb 23, 2011 8:00 pm
by fairspares
ive done what davetomo shows here and it works fine.
