T5 Polini 152
Posted: Mon Feb 21, 2011 7:41 pm
by carbon lammy
thinking of buying a polini 152 kit for my t5,i know malossi might be better but £285 v £135 makes you think,are these kits any good.
Re: T5 Polini 152
Posted: Mon Feb 21, 2011 10:23 pm
by ricalnic
I was certainly impressed by my Polini kit, and never experienced an issue with it. Polini and PM made an excellent mile munchin rally machine. fitted mine with a slightly taller P2 4th gear and never had a problem with the increased 3-4 jump, although the difference was only marginal, but i guess reduced stress on long hauls at speed.
Re: T5 Polini 152
Posted: Wed Feb 23, 2011 12:13 am
by buttontobutton
Good kits as long as they are set up right. Smaller cc but bit more bottom end power than the Mallossi so can handle taller gearing OK. Get the piston to bore clearance checked out before fitting, after this it should be fine if jetted right.
Re: T5 Polini 152
Posted: Thu Feb 24, 2011 2:30 pm
by fajes
had one for some time, works real well and never had any problems.
