T5 classic forks
Posted: Sun Feb 20, 2011 5:13 pm
by Tosh
Please please Please could someone tell me how to get the pivot pin,bearing,seals out of the suspension link at the bottom of the forks. Need to replace them got a bit of play there. Thanks Paul
Re: T5 classic forks
Posted: Sun Feb 20, 2011 7:55 pm
by ABC
use a hydrolic press (a local garage will have one for bushes and bearings)and a long 8mm socket . the socket will press through the bearing and push the pin through and remove the link.. replace the bearings and pin as a set
Posted: Sun Feb 20, 2011 8:13 pm
by wack 63
Piaggio dealers should have a tool to do this job without removing the forks.I have used one before but it really needs two as it is awkward to use on your own.
Posted: Sun Feb 20, 2011 9:20 pm
by Tosh
thanks for that chaps, so you put the socket over the center of what looks like a castle like spring clip and just push through to the other side am i right in what i`ve said
Posted: Mon Feb 21, 2011 10:22 am
by Fruitjuice
You will need to remove the spring clips on both sides before pressing out the pin...
Posted: Mon Feb 21, 2011 10:34 am
by Tosh
ta fruitjuice, whats the best way to remove the spring clips as they are very strong and i can`t seem to bend the tabs up to release them
Posted: Mon Feb 21, 2011 1:00 pm
by Fruitjuice
Hammer and a small chisel to break off several of the tabs, then try to prie it out with a strong screwdriver...
Posted: Mon Feb 21, 2011 1:15 pm
by Tosh
once again fruitjuice thanks allot be in garage tonight to strip down sons forks and wait for parts from beedspeed
