Drilling offset cones....
Posted: Sat Feb 19, 2011 1:10 pm
The offset cones i use keep moving when i put the bolt through and i want to drill the frame, tap it and out and put a grub screw through. Dont want to loctitie it as it would need to be done each time i deropped the engine.
questions i have are:
I have 5mm grubs are these okay?
Whats the min length of Grub screw i need (cant get at the frame to measure depth at mo)?
How close to the outside of the edge can i go when drilling the frame and should the entry point be directly underneath or at an angle?
Is it advisable to try and drill the grub screw hole in the cone whilst its in the frame or best to get the drill tip to go through the frame touuch the cone then take it out a and drill it a bit in a vice?
I think thats it, some obvious questions but didnt want to end up drilling more holes than i need....
ta
Sef
ta
Sef
