Tune a Mugello 186?
Posted: Sat Feb 19, 2011 11:37 am
by Bilko
Been thinking about my old Mugello 186 V2. It's been run/thrashed for a few years and while the LI is in bits and all over the place. I'm going to strip the engine for a service.
While it's apart, is there anything that could be done to the top end to give it a bit more low down grunt?
Is it worth it?
Re: Tune a Mugello 186?
Posted: Wed Feb 23, 2011 6:48 pm
by Bilko
What did I say wrong?
Is a Muggy 186 not worthy?
Posted: Wed Feb 23, 2011 9:28 pm
by coaster
What are you running it with carb/exhaust wise?
Posted: Wed Feb 23, 2011 10:05 pm
by Chris CSPE
Bilko wrote:What did I say wrong?
yes it is worth it, wot port timeings does it run, wot carb and exhaust, is it a standard size crank, there is alot you can do but that depends on wot you've already got. There are some good gains to have for a small amount of work.
Posted: Wed Feb 23, 2011 10:42 pm
by Bilko
Thanks. A 28mm Dellorto and a JL1.
Was going to use a 58mm GP MEC Crank
Posted: Wed Feb 23, 2011 10:58 pm
by sean brady scooters
if its low down grunt changes that your after ,then a crank change wont make any difference to performance,,
however..you could try widening the exhaust port to the max width ..and a pipe change such as the ADS 1 with gearing to suit ..
Posted: Wed Feb 23, 2011 11:19 pm
by Chris CSPE
Give Al a call at Diablo or pm him and he'll be able to offer you some options that have had good results
Posted: Thu Feb 24, 2011 12:16 am
by Bilko
Thanks lads, appreciate that.
I'll definately give Al a call. Should have done in the first place.
