25mm set up.
Posted: Sat Mar 07, 2009 2:42 pm
by Andy Pickering
Stock 200 SIL motor
25mm Dellorto PHBL
Casa inlet rubber and K&N (upright)
RScoot exhaust
Main Jet 102
Idle Jet 50
Slide 40
Needle D26 clip 2nd from top
Atomiser AQ264
Air screw 1 1/2 turn out
Seemed to be fine..but went for a blast this morning and when getting to higher revs seems to be holding back a bit and seems a bit choked up after about 40 mph up until then very smooth and responsive.and starts first kick every time..warm or cold...?
Anyone any ideas on jetting maybe main up a bit.
Re: 25mm set up.
Posted: Sat Mar 07, 2009 8:13 pm
by soulsurfer
Pull the choke on when it holds back and see if it helps. If it does then the main needs to increase.
Re: 25mm set up.
Posted: Mon Mar 09, 2009 1:03 pm
by vespinello
If the choke don't change the situation (ll say that a bigger jet is needed), try to change the needle
I have read that a D29 needle + AQ 268 are recommanded ....
