Lambretta clutch possibilities
Posted: Sat Mar 07, 2009 1:16 pm
Hi.
I am confused by the options in Lambretta clutch.
Possibilities:
1-Original: standard clutch sprocket with 4 original size clutch plates + 3 steel plates.
2-Standard clutch sprocket with 5 thin clutch plates/steel plates.
3-Modified clutch sprocket for 5 original size plates + 4 steel plates. This one can use with 4 plates with more room.
4-Modified clutch sprocket with 6 thin clutch plates/steel plates.
Is this correct?
Then there are different clutch spiders:
1-Original size
2-With long "arms", i think that the foxhat one is this type.
I know that there are different types of steel, CNC, reinforced, ....
But the question is, with the long "arms" one this can touch in the kick start shaft?
Thanks!
Possibilities:
Is this correct?
1-Original size
Thanks!
