Woodruff Key
Posted: Wed Feb 16, 2011 7:08 pm
by Bilko
Finally got back to working on the 250 after a break.
Took the flywheel off and the woodruff key had sheared
Should I be worried about this happening after only about a dozen kicks and about five minutes of the engine running?
I did notice that there wasn't a lot sticking out of the key in the crank before it, but didn't think it would have been a problem.
Re: Woodruff Key
Posted: Wed Feb 16, 2011 8:03 pm
by Triken
In my experience, a sheared woodruff key was caused by the flywheel not being tightened up correctly (slack rather than overtight) and it didn't take much to shear it!! I am not saying that is what caused yours, just that it's what caused mine.
Re: Woodruff Key
Posted: Wed Feb 16, 2011 8:22 pm
by RICSPEED
have you lapped the fly wheel to shaft ?....there my be a high spot on the taper allowing movement
Re: Woodruff Key
Posted: Wed Feb 16, 2011 8:57 pm
by Bilko
Triken wrote:In my experience, a sheared woodruff key was caused by the flywheel not being tightened up correctly (slack rather than overtight) and it didn't take much to shear it!! I am not saying that is what caused yours, just that it's what caused mine.
This was it. I didn't originally have the flywheel tightened.
Thank you
Re: Woodruff Key
Posted: Wed Feb 16, 2011 11:29 pm
by paulmgreen
Sorted then!
Re: Woodruff Key
Posted: Wed Feb 16, 2011 11:42 pm
by Bilko
Yes! I hope!
Re: Woodruff Key
Posted: Thu Feb 17, 2011 7:25 am
by Toddy
Re: Woodruff Key
Posted: Thu Feb 17, 2011 1:12 pm
by Bilko
Glad I'm not the only one to forget
Re: Woodruff Key
Posted: Thu Feb 17, 2011 3:08 pm
by mark
At my age I have to check everything twice or I will forget lol
Re: Woodruff Key
Posted: Thu Feb 17, 2011 6:48 pm
by jonny snatchsniffer
its a bit like forgetting to put your nob away after having a p155
