px200 gear change not nice
Posted: Tue Feb 08, 2011 11:45 pm
1989 spanish iris model, just finishing running engine in since i rebuilt it. 800 miles ago totally standard motor even exhaust, fitted new cruciform, seals bearings and cosa clutch, runs perfectly but gear changes from 2nd to 3rd are very crude and un smooth as if the 3rd cog is spinning and the cruciform is crashing into it bluntly with a real definition.,, at very slow speed its better and if i thrash it in 2nd and then change fast it is better but when you average riding it just feels annoyingly crude, ive had a few p-range 200,s that were similar in the past, has anyone came accross this??? dont really want to just put up with if its just a case of replacing the gears which i do have another set, but the gearbox in engine did look mint, so dont want to pull apart and replace gears if somone out ther says that all p 200,s do that??? any ideas??? ive had a few 125,s that were smooth as f@@k in the gears..?
