SERIES ONE FRAME BREATHER(scooterotica forum bitza )
Posted: Tue Feb 08, 2011 4:33 pm
by RICSPEED
OK with bits sourced off various members(off here and other forums) i now have the most important bit .......the frame
1958* 125 frame breather
i don't expect things to move to quick unless i lash it up in satin black for a while as i have a house to renovate first then build a garage before i can even think about a build..... not to mention a GP to finally finish
(*to be confirmed,need cert)*edit
*came back as 1959 weirdly
Re: SERIES ONE FRAME BREATHER(scooterotica forum bitza )
Posted: Tue Feb 08, 2011 4:38 pm
by RICSPEED
ps i will be on the look out for bits ....but major purchases will have to wait as my c/c has took a hit
edit ........if anyone has a scrap s2 horncast that i can cut bits of to repair the s1 cast(bottom mounts)
Posted: Mon Feb 21, 2011 1:54 am
by RICSPEED
forks from el markio
led rear light ....
bit of a lash up but ill see how it goes
Posted: Tue Feb 22, 2011 12:28 am
by MADSPEEDRB260
Im just doing a Madspeed series 1 looks good mate.
Posted: Tue Feb 22, 2011 2:57 am
by Robi D
How did you do your LED taillight? looks good so far BTW.
Posted: Tue Feb 22, 2011 11:26 am
by RICSPEED
Robi D wrote:How did you do your LED taillight? looks good so far BTW.
it was this type -
sure you can get them cheaper ,motrax i think but i had it given a few years ago and was just sitting in a drawer so i just removed the led/circuit board and mounted on brass computer motherboard standoffs ..ill try rig up a 12v supply and try it
Posted: Tue Feb 22, 2011 11:32 am
by RICSPEED
how about two of these ?
only thing this would not light the reg plate very well
or this?
