PX200 gear selection
Posted: Sun Feb 06, 2011 6:46 pm
by Hotspur
My pal's been round today, with his PX200. The gears are hard to select. First goes in with a big "clunk", and the rest seem to be "sloppy. We've tightened up the cables, and between the headset, and selector box everything is tight. But the headset control seems loose, and changing gear is a pain. I'm not sure where to start looking, but any advice is most welcome.
Cheers Pete
Re: PX200 gear selection
Posted: Sun Feb 06, 2011 9:25 pm
by Danger
have you checked that the back hub is tight , if loose gears will be all over the shop
Posted: Sun Feb 06, 2011 9:27 pm
by A565
I find it's the clutch that needs adjusting when this happens.
Posted: Sun Feb 06, 2011 9:42 pm
by gaz_powell
the above are valid points
take the selector box off and check to ensure the selector rod (which the cruciform is screwed to) is tight - if not it can be tightened with a spanner then re assemble.
to access it take the selector box off - put the bike past 4 gear, undo the nuts and draw off selector box the rod hooks to the selector box arm
see scooterhelp website may help you visualise what is to be done http://www.scooterhelp.com/tips/engine/ ... vespa.html
note that it is opposite hand thread so anti clockwise to tightenen
best of luck
Posted: Mon Feb 07, 2011 8:39 pm
by Hotspur
Many thanks for your words of wisdom all. Gives me something to go away and try now.
Cheers Pete
