welded crank pin for malossi 221 is it necessary?????
ssteam177
Main scooter: vba malossi 221, api series2
im about to change the crankshaft in my malossi 221 from a mazz full circle{ as it proved to be to restrictive at high rpm} to sips version of the worb5 lip style for reed valve. the one with a welded pin was out of stock so ive ordered the version without is it recomended to have the pin welded or is this a bit overkill???
thankyou in advance for any advice given!!!!!!!
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
    Users browsing this forum: Google [Bot] and 13 guests
