ts1 + phbh30 jets help
Posted: Fri Feb 04, 2011 3:38 pm
by alle
Hi, I've a ts1 with taffspeed and phbh30, anyone knowing a decent setting to start working?
cheers
alle
Re: ts1 + phbh30 jets help
Posted: Tue Feb 08, 2011 10:37 pm
by Diablo
Start rich with:
pilot 50
atomisor AV268
Needle X2(probably top clip)
Main Jet 130+ maybe startsafe at 140
slide 40
You may also need to weaken if needs be with:
AV266 and X7 needle and main jets in increments down to 128.
These carbs work well with bellmouths on TS1s so maybe get one of those as well( the plastic ones are cheap)
A powerjet isn't absolutely neccesary but carburation is improved with one of the camlam ones fitted.
Posted: Wed Feb 09, 2011 9:40 am
by alle
thanks Diablo, good start!!!
Posted: Fri Feb 25, 2011 10:04 am
by OLDSKOOL LAMBRETTA
hi diablo, is the 50 pilot jet richer then a 55 pilot jet, cheers
Diablo wrote:Start rich with:
pilot 50
atomisor AV268
slide 40
Posted: Fri Feb 25, 2011 11:02 am
by Diablo
No weaker
Posted: Fri Feb 25, 2011 11:13 am
thanks for the help diablo, cheers martin.
Diablo wrote:No weaker
