54mm stroke crank
Posted: Mon Jan 31, 2011 10:52 pm
by mark
does anyone do a 54mm stoke crank? thanks
Re: 54mm stroke crank
Posted: Mon Jan 31, 2011 11:10 pm
by rakki
AF Rayspeed has them on their website.
Posted: Mon Jan 31, 2011 11:12 pm
by Ian Hepworth
Omega (went on to be Mec-eur) made some in the 80s. I got a used GP one recently to use with my autisa kit.
Posted: Mon Jan 31, 2011 11:13 pm
by rocho68
What u planning now kidda!
Posted: Mon Jan 31, 2011 11:20 pm
by mark
ktm sx125 looks similar size spigot to small block casing and kicks out 33bhp and 36bhp when turned to 144 big bore . already know dtr 125 ignition will fit gp boss.
Posted: Mon Jan 31, 2011 11:23 pm
by Ian Hepworth
mark wrote:ktm sx125 looks similar size spigot to small block casing and kicks out 33bhp and 36bhp when turned to 144 big bore . already know dtr 125 ignition will fit gp boss.
run it 58mm and take advantage of the extra cc's? or are you trying to do a bonkers 125?
Posted: Mon Jan 31, 2011 11:25 pm
by mark
legalish 125 i think, mind you 58mm and packers might work
Posted: Mon Jan 31, 2011 11:39 pm
by rakki
Would it be possible to utilize eccentric crank pin facing inwards? Assuming that this setup needs "exotic" con rod and therefore custom made crankshaft.
Posted: Tue Feb 01, 2011 10:22 am
by bsso78
Ive got a 54mm stroke crank from my old Group 3 150,it was getting tired so had a new bearing and rod fitted but never used after that if anyone wants one
Posted: Tue Feb 01, 2011 12:56 pm
by mark
How much?
